Radiator Light
EDIT :
The light is located in the upper right of the tach, this is a collant light and not a windshield washer fluid light, right... because that is full as well.
ok, thank you very much! it has been driving me crazy.
Yes, i just did that today, but that bothers me for some reason
You might also try draining some of the coolant, removing the sensor, and cleaning it with some electronics parts cleaner (or perhaps brake parts cleaner). It's possible that it's just gunked up with coolant crud and needs to be cleaned out. I'd try that before buying a new one.
If you keep the electrical connector unplugged, you just won't get any low coolant light. I always keep an eye on the temp gauge just to make sure everything is ok, but if you happened to miss it, you'll get a CHECK ENGINE light if the engine begins to overheat. Just so you know, as there is somewhat of a 'backup' warning to the low coolant light.
