car won't stay running
speed density? i really don't know what all that is you would have to explain to me...basically the car runs like it did when i accidently left the maf sensor unplugged...however, i'm POSITIVE it is plugged in now...also i don't know if i mentioned it before but car smokes like a champ now...and it runs like it's out of gas (which i know it isn't) ie bucking and loss of power then random power surges... About your reverse. Pull the ENG SEN fuse from under the hood and check it. If it's blown then there's your problem. If you don't have another fuse just use your horn fuse as a temp.
as for the comment about unplugging the maf and trying sd... i dont think that will work either. its not that simple.
as far as the reverse lockout... can you muscle it into reverse? mine wont let me over sometimes and ill need to use two hands to get it into R. if you checked the fuse under the hood and it was good, then get under the car and look at the solenoid on the side of the tranny. im not sure exactly which side its on, but on one side is the cags (IIRC) and on the other side of the tranny is the rev lockout.
I should know by later today, if we have that problem fixed, with the blowing the main sensors fuse. If that's fixed, we'll tune it, and you'll have it back within the next day or two.
thanks dino...i'll be there around 10 tomorrow to pick it up...i guess the power was so-so...i didn't really know what to expect since i didn't know how well the heads were ported...all i noticed is that the intake ports were smoothed up a little when i took the intake off...i guess it's not bad for cam only but for heads/cam it's not all that great...it's all good though...as long as it drives well and stuff...i'll prolly be stepping it up in a year or two anyhow Kevin, what happened man? How bad did you hit the dirt on your accident? MAF never showed any problems when I had her.
Dino at RevX:
The car was mine up until about a month ago. I'm responsible for the work. What exactly was wrong with the wiring? Can you be specific?
Btw, what were the numbers after tune?
Dino at RevX:
)...i'll let you know and post up the graph when i get a chance...it prolly won't be today or if it is it will be later...i'm heading out to crescent beach after i get the car...Kevin
The wire protecting loom didn't get put back on, and there are two brackets on the back of the engine that are metal, that hold the wiring harness securely, and they rubbed through the outer layer of the wires, and shorted them out. That's why it kept blowing the main fuse for the sensors, and that's why the MAF wasn't reading.
Car runs great now... cold start up, hot start up, doesn't matter. Now you have to think about getting a clutch and maybe some tranny work. It doesn't like going into the gears too smoothly... especially 3rd. Nice car, just needs a little love.
