Sponsored by: CARiD
Fuel pressure
Old May 15, 2005 | 05:19 PM
95camaroz28's Avatar
Default Fuel pressure
I tested my fuel pressure, with just the key turned it puts out like 15 psi. running it does a little bit more. I know that its supposed to be in the 40's and 50's. what would be the problem. New fuel pump. or is there a leak. but i do not see any gas dripping anywhere on the car. help please. the car will idle than it will die, and when i give it gas it dies some times comes back but still runs like junk. What do you think new fuel pump?
Old May 15, 2005 | 09:52 PM
MEAN LT1's Avatar
My first guess would be to replace the fuel pressure reg. THen start looking at your fuel pump.
Old May 15, 2005 | 10:35 PM
where the heck is that and how much does it cost to replace,and how can i tell if it bad?
Old May 16, 2005 | 04:52 PM
94strokedz's Avatar
Its at the back of the intake manifold, relatively hard to get to. A few companies make an adjustable rebuild kit for this.
Old May 16, 2005 | 05:00 PM
the car has 113000 on it with stock pump, i already got stuff coming for the fuel pump and the gas tank is almost off, ill try fuel pump first, even tho its not cheap
