Sponsored by: CARiD
window problem
Old May 19, 2005 | 10:56 PM
FormulaFire's Avatar
Default window problem
My driver side window has recently decided to go up and down only when it wants to. When I roll it down or up it will only go so much then stop. It won't go up or down. Then I wait a couple of minutes and it will move a little. It's kind of like it is "charging" up to move. Anybody know what is the cause? How to fix it?
Old May 19, 2005 | 11:51 PM
Dal1as's Avatar
You need to replace the window motor. Do a search and you'll find a wealth of information. Easy to do and the window motor through autozone is only like $60.
Old May 20, 2005 | 01:14 AM
Daley's Avatar
Yep - that's right. The motors wear out, and become very sluggish. The reason it stops for a few minutes is because the circuit-breaker in the fuse-panel is tripping and then resetting after a few minutes. BTW, the motors from Autozone carry a lifetime warranty, if I remember correctly.
Old May 20, 2005 | 09:58 AM
VIP1's Avatar
Copy & Paste Moderator
https://ls1tech.com/forums/showthrea...ighlight=motor
