Sponsored by: CARiD
T-top Tapping/Knocking
Old Jun 22, 2005 | 11:58 AM
SilverV6Camaro's Avatar
If you use the silicon you have to do it every other time you take in on and off. The rubber would be a more permanent solution if I can find a cap that size.
Old Jun 22, 2005 | 01:41 PM
grimm2420's Avatar
I had a tapping coming from my driver's side t-tops too. I found that the problem was coming from where the metal pin comes in contact with the metal guide on the t-top itself, not the guide on the windshield side where it attaches. I put some thin tape around the pin where the it would contact the guide when closed and the tapping stopped.
Old Jun 22, 2005 | 01:51 PM
That's a good idea. I might try that on the pin where it goes into the windshield and on the t-top itself. Thanks.
