Traction Control doesn't Turn Off???
It does not come on when I press the Traction Control switch.
Any suggestions?
Thanks!
No, the "TCS OFF" light does not come on, and the light within the switch itself does not come on either. I suspect that it is the switch since nothing about it is right. What is the availability of that switch of yours? The dealer wants around $ 25 for it. Thanks.
Replacement instruction:
Removal Procedure
1. Unsnap the front floor console accessory trim plate (2).
2. Electrical connector from the traction control switch (4).
3. Electrical connector from the convertible top switch (3), if equipped.
4. Unsnap the traction control switch (1) from the front floor console accessory trim plate (2).
Installation Procedure
1. Traction control switch (1) to the front floor console accessory trim plate (2).
2. Electrical connector to the convertible top switch (3), if equipped.
3. Electrical connector to the traction control switch (1).
4. Front floor console accessory trim plate (2).
See attached diagram.
Part number for the switch is 10273882... GM list price is $28.17
Removal Procedure
Thanks very much, hope I can return the favor sometime.
