Sponsored by: CARiD
jack stand spots for 91 Firebird
Old Jul 7, 2005 | 12:26 PM
Firebird_91's Avatar
Default Help with jack stand spots
i need to do some work on my exhaust on my 91 firebird. all i need to know is where the jack stand spots are. not just any spot!
if anyone has the diagram or picture from the manual would be greatly appreciated. thanks!
Old Jul 7, 2005 | 01:11 PM
transamjunkie's Avatar
if you use factory jacks, there is a notch that they fit into underneath the car. Unfortunately if you have ground effects they will be hard to see, and the front notch would be a little in the way...really close to the catalytic converter/y-pipe...would probably be in the way. If you remove your factory jack, there should be a picture/diagram on the jack itself showing where to put it exactly.
Old Jul 7, 2005 | 05:50 PM
FBDYLVR's Avatar
http://thirdgen.org/techbb2/showthre...=jacking+point
That should cover your question.
