Sponsored by: CARiD
windshield fogging up
Old Jul 15, 2005 | 04:15 PM
01_ram-air's Avatar
Default Help please...windshield fogging up
I just bought my 2001 Trans Am WS-6 A4 and I've taken it to the drag strip twice now. Both times I've had a problem with the entire windshield fogging up instantly right at the 1/8 mile traps. I have to throw the defroster on immediately so I can see. Has anyone else encountered this? What is the reason that the windshield is fogging up?
Old Jul 16, 2005 | 08:56 PM
FelixIlka's Avatar
I don't know the reason behind it, but if you pick up some Rain-X anti-fog wipes those work pretty dang good.
Old Jul 17, 2005 | 12:55 AM
BADMOFO's Avatar
Cuz I AM a BADMOFO
I agree. That "Fog-X" works pretty good. Try putting your heat/air control on the "recycle air" selection which lets in a bit of air...and make sure that the defroster selection is on...even without the fan on it will circulate a bit of air over the windshield and help out with the fog.
Old Jul 17, 2005 | 08:17 AM
30thanniv's Avatar
Fogging up of the windshield is usually indicative of a leaky heater core. Perhaps under racing conditions yours is leaking. Usually you can smell anti-freeze inside the car.
Old Jul 17, 2005 | 09:42 AM
01_ram-air's Avatar
I haven't smelled any anti-freeze in the car. Thanks for the tip though, I will look into it.
Old Jul 18, 2005 | 08:33 PM
8-Pack's Avatar
That was my guess too (leaky heater core). You might not smell it at first but if yours is leakng you will soon enough, also check under the car around the firewall on the passenger side for leaks. BTW if your heater core is bad its a simple fix.
Old Jul 19, 2005 | 01:29 AM
Jay_Dogg's Avatar
I also agree, a heater core will cause it. Its happened to me before.
