Sponsored by: CARiD
Daily Driver Cooling Problems
Old Jul 22, 2005 | 05:40 PM
JustaStockHawk's Avatar
Default Daily Driver Cooling Problems
Ok i have a 1994 Grand Prix GTP that i recently bought in Colorado to bring to AZ to go to College. When I get down to AZ the alternator dies so I replace it twice(the first one we got was dead too ). Now the cooling system is having trouble cooling the car, I thought this might happen with the difference in heat since this car is a Colorado car. So after checking everything over, I found out that my passenger fan is not working. So I pulled out the fan and ran jumper wires to the battery to see if the fan motor was dead or if it was a wiring problem. The fan worked with out any problem. So I chased down wires and found nothing to be wrong. But I decided to hard wire the fan so that I could control when it turns off and on. Here is where my problem lies... I have power at the switch, I have power at the wire coming to the fan, I have a good ground. Why isn't the fan working? My thought was that the wire I was using wasn't moving enough power through it. So i took some wire like what I used and the fan worked just fine off of the battery. I am really confused by this, since I have everything to make an electric motor run, but the electric motor is not running
Any help would be awesome
John
Old Jul 22, 2005 | 06:33 PM
Nasty N8's Avatar
Maybe the fan is rubbing when installed and won't turn? Or you just have to have a bad connection somewhere.
Nate
Old Jul 23, 2005 | 02:20 AM
This was with the fan sitting on top of the motor with nothing against it or anything. I tried every possible thing i could think of. i think i have it figured out though. i hacked into the power of the other fan. and since every where you go you have the ac on i wont have any problem with the fan being on at all times. thank you any way for your help... i never figured out why that connection didn't work... i hate electronics with a passion...
