Intrigue Dual Climate Air Conditioning Problem
I know I don't have an LS1 motor or a sports car, but I was hoping to maybe get some troubleshooting advice for the A/C system in my 1998 Olds Intrigue (3800 series II motor).
The system is a auto dual climate control A/C. Just recently the two driver side vents blow "vent" temperature air while the passenger side blows cold air with the overall temp setting set to 60 degrees. I took it into our local Pontiac dealership and the mechanic swears it is the compressor leaking. He said the system shuts down one side when the compressor is low on freon. This does not sound accurate with what is really going on. Why would one side shut down even though the passenger vents are cold??? It sounds to me more like some kind of dual plenum valve or something would be malfunctioning if there is such a thing. I have purchased a new compressor from Auto Zone ready to go in, but something tells me this won't fix my problem. Although I know how, I would rather not infiltrate my A/C system by changing the compressor, accumulator, and orfice valve if I do not have to. Any advice on this would be much appreciated.
Regarding blowing cold on only one side, here's a thread about what sounds like the exact same problem on Corvettes: http://forums.corvetteforum.com/show...5&page=3&pp=20
Moving the left actuator gear tooth compensates for a binding left temp door or a door that has extended travel due to wear. The compensation is calibrated when the battery is connected and the control head relearns full door positions during initialzation. Usually this senario is only detected after disconnecting the battery for other reasons. If you install a 2001 control head on a 97-2000,indexing the gear tooth is not required.
It is also possible that the left door actuator is simply faulty and requires replacement with no indexing. This is a common occurance...
This will result in cold air distributed out the right vents and warm air out the left vents
... the freon recovery machine pulled out .26-.28 of freon out of my car. we then pulled a vacuum on it and it held then filled it up and it was like new.
I had only about 20 psi and I've got a leak somewhere. It defintely beats fumbling with the actuator gear.
) Last edited by ACW; Jul 28, 2005 at 11:30 PM.
