Sponsored by: CARiD
Weird problem, electrical system?
Old Aug 1, 2005 | 05:43 AM
Rebelord's Avatar
Default Weird problem, electrical system?
Heres the deal. Lately when I go to start my car sometimes it takes it a bit to start. Hell, the other day it started, ran for sec and shutoff. I then restarted and my ASR OFF light stayed on. I thought from that I had a ABS sensor going bad or whatnot. I turned off the car and restarted fine and light stayed off. Good. Also lately when I start my car for the firts 10mins or so I get this high pitched whine coming from the speakers. I turn the volume all the way down and its there, as I increase RPMs the high pitch noise gets louder. Then tonight after cruising around with my buddy, when I go home. I noticed that my volts gauge was down near 8volts. I though, oh s&!t my alternator, but once I increased rpms the volts went up and stayed there. I havent touched anything electrical on this car since I have had it. I've had it for 10months now. The only thing I have done recently was replace my plugs and wires. I had to put the cheapo AutoZone wires cause I didnt have the money for MSDs or whatnot. I had fried 4 wires from hitting my headers. Well anyone thats good with electrical would be appreciated for some help. Thanks.
TIA, Ski
Old Aug 10, 2005 | 02:34 PM
WhiteBird00's Avatar
Ungrounded Moderator
Have your battery load tested and replace it if necessary. All of the symptoms you describe can be caused by a failing battery.
Old Aug 10, 2005 | 04:43 PM
3rdgenguy's Avatar
ya a bad cell in the battery would cause the car to die (by shorting out) and possably causing the alternator to stay full fielded all the time to try to keep a charge in the battery. Just test the battery cheap and easy before throwing parts at it
