Sponsored by: CARiD
A/C evaporator/pulling dash
Old Aug 5, 2005 | 04:31 AM
DONAIMIAN's Avatar
Default A/C evaporator/pulling dash
Has anyone done this before. How long will it take me. I charged up the a/c today and ran some dye through the system. Couldnt find the leak anywhere. Once I got home and turned the car off I could hear hissing under the dash (can hear it really good when I put my ear to the center vents). When I popped the hood its comming from the passenger side firewall area. TIA.
Old Aug 7, 2005 | 03:53 AM
DONAIMIAN's Avatar
up up up
Old Aug 7, 2005 | 08:50 AM
DaddySS's Avatar
First, you need to be careful using the hissing noise as your guide. The sound travels across aluminum and it may be leaking elsewhere but you hear it there. I say that because the evaporator coils are not a very common cause for a leak.
Old Aug 7, 2005 | 09:46 PM
DONAIMIAN's Avatar
A while back I had a spec stage 4 let go and it put a huge gash down the side of the box, I thought it was just a hole in the box, sealed the box, charged the system, and its a leak. Ran dye through the system and looked for the leak and didnt see it anywhere under the hood (where I hoped it to be).
