Sponsored by: CARiD
Oil Change. When there is a will...
Old Aug 5, 2005 | 05:40 PM
exit's Avatar
Default Oil Change. When there is a will...
When there is a will there is a way. Me and my friend were gona gut my cats last night but discovered that I had none ... so we settled for a Oil change....
Everything went smoothly till i tryed to get the filter off.... so tight i couldnt get it off by hand..... and i didnt know i had the oil filter remover in my tool box because i had never used it before in my life and my dad apparently left it when he moved out..... So..... we drilled into the filter and loosened it a little that way ... till the bit was all bent out of shape..
Then i found the tool and got it off..... but it was pretty funny night...
I've never had so much trouble getting a damn filter off
Old Aug 5, 2005 | 06:05 PM
chupr0kabra's Avatar
If you ever get it that stuck again, punch a screw driver into the filter at an angle. Instant handle.
-Mike
Old Aug 8, 2005 | 01:13 AM
The PAT WS6's Avatar
hahah ya that tool deff. helps in gettin that filter off
Old Aug 8, 2005 | 04:51 AM
2MuchRiceMakesMeSick's Avatar
Get a oil filter socket. I had to have one after i got long tubes on my SS. You can pick them up just about anywhere (walmart even has them)
