My AC is leaking inside of the car
There's an 'evaporator drain tube' that can get clogged/blocked and cause water to leak into the passenger compartment. The AC evaporator core could need replacing, but a clogged drain tube is more common, not to mention easier/cheaper to fix! Or if the tube is damaged/leaking instead of just clogged, might have to replace that.
Froma under the car, the weephole is between the framerail and the cat (pAss. side, obviously). The hole is the size of a #2 pencil (as described by someone here than helped).
You will see it as you're looking up between the frame and the cat, it's part of the black box. I just slowly poked it my finger, and she poured...
Aria
