Sponsored by: CARiD
Power steering pulley removal
Old Aug 9, 2005 | 10:34 PM
MikeD's Avatar
Default Power steering pulley removal
I have a friend who has a 94 Formula. He has to replace the water pump and he can't get a bolt off because the pulley is in the way. Does he just need a pulley puller? I'm 2 hours away, so I'm not exactly sure what he's looking at. Can anyone offer some help?
Old Aug 9, 2005 | 10:42 PM
brandboZ28's Avatar
He has to take the socket off of the bolt before you can get the bolt out. Thats if he is talking about the middle bolt on the passenger side...
Old Aug 10, 2005 | 03:19 AM
Alex94TAGT's Avatar
He does NOT need to remove the power steering pump pulley.
Like brandbo stated, I would tell him to use a 'swivel socket extension' to break the bolt loose, then once loose, remove the socket wrench, and back the bolt out by hand. He should be able to clear the pulley.
Old Aug 10, 2005 | 08:35 PM
wicked_95z's Avatar
There should be holes in the pulley where you can stick a socket through. At least there are on my 95 or do I not understand? Why does he need to pull the P/S pump to get to the water pump anyway?
Old Aug 10, 2005 | 09:16 PM
matt94z's Avatar
I bought a special puller just for this purpose. I can have it off in about 2 minutes. It is much easier than spinning the ps pulley and loosening the whole pump. I got mine at a Carquest dealer for around 50 bucks.
Old Aug 11, 2005 | 05:33 AM
wicked_95z's Avatar
Are we talking about a V8 here?
