Sponsored by: CARiD
99 ta fluid spill
Old Aug 10, 2005 | 07:55 AM
white99's Avatar
Question 99 ta fluid spill
I took two pictures of fluid that I think may have been a combination of antifreeze and/or something else. I drive a 1999 trans am M6. It looks greenish on the outside of the fluid and whiteish on the inside where it dried. It's almost powdery looking on the inside as well. I wasn't able to see what it looked like when it first came out because I noticed it when I came home from work. Can anyone explain what this is? I checked my antifreeze level and it's normal. Where could this have spit out from. It happened from a cold start. Is there a purge valve that could've spit it out? And why? Everything seems to run fine. Although, even before I found this fluid, since I've owned the car, I have had a hesitation at 46MPH. Never at any other speed.
Old Aug 10, 2005 | 09:02 AM
y2k_ta's Avatar
'Bird Director
From: Central Indiana Honors: 4th grade spelling bee contestant
The fluid definitely sounds like antifreeze. It doesn't take that much fluid to make a small puddle, so you probably wouldn't notice any level change for a long while.
Old Aug 10, 2005 | 08:27 PM
white99's Avatar
Where would it come from? Is there a purge valve? What would cause this from a cold start? It's garage kept so the car was at around 80F degrees.
