Sponsored by: CARiD
Any How To's on an AC leak
Old Aug 17, 2005 | 12:39 PM
Justin01SS's Avatar
Default Any How To's on an AC leak
Problem: There is a water leak in my front passenger seat when ac is on or has been on. ( Sounds familar)
I have heard a bunch of people diagnose this a a clogged drain of some sort. Any have a small write up, or could take the time to do one on how to fix this problem? Where the drain is, how to unclog it, etc. Thats alot guys!!
Justin
Old Aug 18, 2005 | 07:43 AM
ACW's Avatar
ACW
The evaporator core's drain tube
http://www.thebenzbin.com/air_conditioning_drain.html suggests unclogging it using compressed air or a screwdriver.
Old Aug 20, 2005 | 09:11 PM
JasonWW's Avatar
I think the best thing to do would be to jack up the car, crawl under there and look for the water drain stains to locate the drain hole. Then stick a wire hanger up in there and gently poke around. Don't jam it in there or you could damage the evap core, but that's the easiest way I can think of unless you want to pull the dash out.
You might try blowing compressed air up the drain, instead of a wire hanger.
Old Aug 20, 2005 | 10:09 PM
Justin01SS's Avatar
Ill crawl under there tomarrow. Thanks for the help guys
