Sponsored by: CARiD
cooling fan issues
Old Aug 20, 2005 | 04:48 PM
my01camaroz28's Avatar
Default cooling fan issues
ok guys, heres my problem, ive got a a 95 firebird formula (obviously lt1). The cooling fans quit working the other day, and havent started since. i can manually junp fan relay # 1 and both cooling fans will come on. i checked the wire from the pcm to the relay (ground signal) which according to my books is a dark green wire coming from the red connector pin number 11. resistance to ground at the pin for the signal at the relay is infinite. i back probed the ecm connector and measured the resistance, still infinite. assuming the meter is good, and back probe was good, (im pretty sure that they are) is the control module shot? what temp should the pcm switch low fan speed on? thanks in advance for the help.
