Sponsored by: CARiD
Squeaks when cold
Old Aug 24, 2005 | 09:24 AM
2000WS6TA's Avatar
Default Squeaks when cold
whenever i start my car in the morning or after its cooled down somthing is squeaking. my dad thinks it could be my water pump. my ? is. is that right or could it be somthing else?the squeak gets quicker and faster when the engine is reved higher so its def. somthing to do with the betls or pump or somthing.please help.thanks
Old Aug 24, 2005 | 12:13 PM
jkichline's Avatar
When is the last time you replaced your serpentine drive belt?
Typically, when the belt is worn out, it squeals until it warms up. The water pumps in these cars are usually good for 100,000 miles or more.
I would replace the belt first. If you already did, check the belt tensioner. This should have a tight springy feeling. If not, try lubing it up. If that doesn't work, you might have to replace it.
