Sponsored by: CARiD
Bit of an electrical problem... Help!
Old Aug 28, 2005 | 04:27 PM
musclehead's Avatar
Default Bit of an electrical problem...HELP!
For nearly a year now I have been plagued by an electrical problem.
Started, when I was out on a cruise on a hot *** day. Coming home from the cruise I decided to run my A/C. As I got into stop and go traffic I glanced at my gauges (as I do often) noticed my voltage gauge was bouncing all over the place, then it began to dip really low (into the low yellow). My car soon began to run rough so I pulled over, popped the hood, and checked things over. I immediately noticed that I had battery acid all around the battery and surrounding area. I began to flush the area clean with water, but it was to late for my paint...ERRR!!! I had just installed a new optima dry cell battery days earlier, so I was like WTF!
Anywho I pulled the SOB out took it back to Pep Boys and exchanged it for a new one. Slapped the new one in, chilled for a while and let things cool down, then proceeded to be on my way. I did not make it far before the same problem popped back up;however I was kinda far from home and said **** it and kept on truckin. The next morning I traded in the optima for a wet cell, along with a new alternator.
Old Aug 28, 2005 | 04:49 PM
musclehead's Avatar
Anywho I pulled the SOB out took it back to Pep Boys and exchanged it for a new one. Slapped the new one in, chilled for a while and let things cool down, then proceeded to be on my way. I did not make it far before the problem popped back up;however I was kinda far from home and said **** it and kept on truckin. The next morning I traded in the optima for a wet cell, along with a new alternator. I figured this would solve my problem, but it really didn't. My voltage gauge sometimes dips low into the yellow but only a hot day. On a cool day or at night the gauge may bouce, but will not dip low. I assume that the heat soak of the engine bay is a contributing factor. Problem is I don't know what the real problem is.
any ideas guys? Sorry for the long post.
Old Aug 28, 2005 | 05:23 PM
slowpoke96z28's Avatar
i believe you had more than one problem.i think it was partly alternator related.normally a battery will spit out acid if it gets charged too fast(i.e. excessive output from the alternator) i'd also check it with a multimeter while turning different things on and off to see exactly when the problem occurs. then check that circuit for excessively high/low resistance.
Old Aug 28, 2005 | 06:13 PM
musclehead's Avatar
Ok.
Funny thing is this now happens when I am not running any accessories. But I will do as you advised, thx.
Old Aug 29, 2005 | 12:06 AM
NXSLT1's Avatar
Check all yer body/chassis grounds under the hood.
