Sponsored by: CARiD
No rear defrost
Old Aug 28, 2005 | 11:06 PM
phoenixv8's Avatar
Default No rear defrost
Tried to use it for the first time and didn't work. Any ideas?
Thanks
phoenixv8
Old Aug 29, 2005 | 04:57 AM
ACW's Avatar
ACW
Could be a bad connection or short, in the HVAC control connector or in the rear defogger grid's circuit. Or the HVAC control assembly might have to be replaced. Or the grid could be bad, in which case it might be repairable with one of those defogger-line-fixing kits, or else the only option might be replacement (i.e. the whole back window be replaced).
Old Aug 29, 2005 | 08:42 AM
jkichline's Avatar
First, you should check the fuse...
Old Aug 29, 2005 | 10:09 AM
ACW's Avatar
ACW
Good point, doh, should start with the obvious
Old Aug 29, 2005 | 05:04 PM
jkichline's Avatar
If I had a dime for every time I didn't check the obvious.....
I am the master of turning a 5 minute job into an all day event....
Old Aug 29, 2005 | 08:34 PM
phoenixv8's Avatar
thanks guys ill check the fuse in the morning!
