Sponsored by: CARiD
wtf? (starting problem)
Old Sep 6, 2005 | 09:40 PM
UGotBeaT's Avatar
Default wtf?
well i went to start my car cause it hasnt been started in like a month and it wouldnt start turn over or nothin... then i started hearin this quiet knockn noise by the battery and the keys werent even in the ignition???? whats the deal?
Old Sep 7, 2005 | 05:27 AM
IMJ's Avatar
IMJ
check the relay's then the battery hope this helps.. oh yeah if that dosent work get in the car try the key if that dosent work press lock, lock the doors when your in the car, then press unlock, then try to star the car... sometimes the car is stuck in protection mode.... usally this works if not disconnect the battery....
Old Sep 7, 2005 | 07:36 AM
777's Avatar
777
If you have the door open or the lights on or anything it will make that knocking noise. It just means you have a dead battery, which after a month, is nothing unusual.
