Sponsored by: CARiD
AC compressor issue
Old Sep 9, 2005 | 12:06 AM
DarkFormula's Avatar
Default AC compressor issue
My V6 Coupe seems to have a problem with the AC. It's fully charged and doesn't leak (I have a gauge), yet when you turn it on, it blows warm air.
When the AC is turned on in the HVAC controls, there's no power going to the compressor via the harness plug into the head unit itself, this was verified with a test light. I've checked the relay and all associated fuses, which are in good, workign order.
Could it be the pressure cycle switch that runs inline with the low side? Anyone have any other guesses as to why there's no power getting to the compressor?
Thanks.
Old Sep 9, 2005 | 05:25 PM
gwj's Avatar
gwj
From: Live Oak, FL - in the woods where the creatures lurk.
You could use a scanner like Autotap to check the output from the pressure sensor. At least you can on the LS1's.
Old Sep 10, 2005 | 01:03 AM
I'll try that later today. Thanks for the idea.
