Sponsored by: CARiD
oil change light??
Old Sep 9, 2005 | 05:37 PM
slpss9723's Avatar
Default oil change light??
I just changed my oil a little less than 1000 miles ago, but actual time that has gone by is about 2.5 months at least......my oil change light came on.... so i checked my level and it was perfect, no burn off and only slight discoloring of the oil, but there usually isn't any after 3000 miles so i definitely wouldn't expect any after only 1000 miles.......eventhough i don't drive her on a daily basis, when i do drive i usually drive the car pretty hard and i might be imagining it, but it feels like she doesn't pull quite as hard.....or maybe it's just because it is so damn hot out.....any thoughts on this.........edit.....oil i use is Castrol Syntec 5-30
Old Sep 9, 2005 | 05:46 PM
SiL3NtXWS6's Avatar
hold down odometer reset button till it goes away.
or
floor gas pedal 3 times with the key in the ignition (car off)
Old Sep 9, 2005 | 05:50 PM
Z'mnypit's Avatar
Thats what I do, turn the key in the run position, mash teh gas pedal 3 times till it goes off.
Old Sep 9, 2005 | 06:01 PM
slpss9723's Avatar
yeah i know how to reset it, but i was just wondering if there might be a problem.....educate me here, but i thought the sensor that trips that light works based on oil wear does it not????
Old Sep 9, 2005 | 08:26 PM
USMARINE1108's Avatar
I believe it goes off of RPM's, not time, or fault reporting. Just keeps track of how many Revs are on the motor since the light was last reset.
Old Sep 9, 2005 | 10:03 PM
slpss9723's Avatar
oh.......hee hee hee ......like i said i drive her hard
Old Sep 9, 2005 | 10:08 PM
S1LV3R's Avatar
Did you reset it when you changed the oil? Because if you didn't, it doesn't know you have fresh oil. It's just gathering data from the last time it was reset. Your driving habits will dictate when it comes on not the condition of the oil.
