Steering wheel wobble after driver side oversized pivot pin installed
Hey guys, had a question on what my next step should be. Ive replaced the drivers side oversized pivot pin and it still it has movement, should I attempt to do the same to the other pin or just pay to have someone dive into it. Im confident I can replace the passenger pivot pin. Im assuming replacing that pin pin would be tearing into it as if you were replacing the ignition switch that way you can remove the plastic trim? Any insight is appreciated thanks.
