Just killed My compressor
All i really did was revved it up, well i was taking off rather fast and i heard a woosh, left a trail of refrigerant all the way down the street. I looked under the car and the whole area around the compressor is wet and the compressor has green **** dripping from it. Definitely thew oil. I'm gonna jack it up to see if it isnt just a loose fitting, but i doubt it.
"Inspect the refrigerant pressure sensor.
Inspect the service valves.
Inspect the lines.
Inspect the evaporator inlet/outlet.
Inspect the accumulator dryer inlet/outlet connections.
Inspect the compressor rear head.
Inspect the housing joints.
Inspect the O-rings for damage, dirt or lack of lubrication.
The primary seal for the service ports is the sealing cap. The cap contains a specially designed O-ring or gasket which provides a leak free seal. Should the cap be loose, missing, or the wrong usage, a loss of refrigerant could result."
transam1998: You know, it happened at WOT. I heard this could be fixed in tuning but everybody i know that tunes doesnt know anything about it.
I'd like to see that!
