Sponsored by: CARiD
Weird electrical problem
Old Sep 15, 2005 | 10:45 PM
thaar's Avatar
Default Weird electrical problem
About 3-4 weeks ago I went to test my battery and found that it was dead so I bought a new one. I drove the car that day and since then it has sat in the garage. Tonight I went to grab something out of my car but my remote didn't work. Once in the car, I put the key in the ignition to see if anything worked and nothing. I broke my trickle charger out and it stated that my battery was charged. I checked to make sure the battery cables were hooked up fine and they were. Even with the charger still hooked up, I tested to see if I got any juice. Dead as a doornail.
How can this be? The car worked a few weeks ago, nothing had changed, the battery is relatively new and, according to my charger, is fully charged. What do I need to check or what could be the problem?
Old Sep 15, 2005 | 10:59 PM
SUX2BU's Avatar
Unplug your battery and clean the terminals with a wire brush and some coke. yes coca cola. it eats all that corosion.
Old Sep 16, 2005 | 08:28 AM
thaar's Avatar
Its a brand new battery, so there is no corrosion.
Old Sep 16, 2005 | 12:41 PM
SUX2BU's Avatar
i meant the battery cables not the battery terminals.
Old Sep 24, 2005 | 10:37 AM
badride5's Avatar
It does sond like a loose or corroded terminal. Clean em and tighten up. If batt is at full charge and that does'nt help check the other ends of the cables.
