Anything wrong with this radiator flush method?
Open the valve (****) on the radiator and let it all drain out. Then leave the valve open and letting the engine run with a continual water flow going into the radiator from a hose into the radiator fill cap, [b]with the radiator valve (****) open to let the coolant/water keep running out?
Maybe let it idle for 30 minutes like that or until the system is just colorless water flowing through it.
Thanks.
We might have to let it idle until it opens, then open the (****) and let it drain. Then run the constant fresh water.
BUT....will the rush of cool water hurt the block or heads after they are warm?
Or is the flow the other way?
