Sponsored by: CARiD
SES Light?
Old Sep 19, 2005 | 10:25 PM
marine_z28's Avatar
Default SES Light?
I have a 97 Mazda 626 with 98,000 miles on it. the SES light came on last friday and i took it to autozone to check the code. He used the actron code reader and the code was P0240, the catalyst system efficiency for bank 1 is below threshold for the current engine operating conditions. The guy at autozone said i might have a vacuum leak or and oil leak. He confused me. Does any one have any suggestions on what it could be? Thanks.
Old Sep 19, 2005 | 11:30 PM
ACW's Avatar
ACW
Probably O2 sensor or bad cat Correct code for that is P0420, btw.
https://ls1tech.com/forums/pcm-diagnostics-tuning/44855-p0420-cat-o2-sensor-gone-bad.html
https://ls1tech.com/forums/pcm-diagnostics-tuning/41927-code-p0420-keeps-coming-up-what.html
Old Sep 20, 2005 | 07:14 PM
zeppelin77's Avatar
with a po420 if you dont have any o2 codes that accompany it,which if you did you would diagnose them first,from my experiance your looking at a converter effiency problem.The computer moniters the front and rear o2s.Also make sure theres no exhaust leaks,probably gonna have to replace cat!
