Headlight problem on my TA
edit: Well I just went outside and messed with it. I manually raised it up a bit and then lowered it. Then I flipped the switch and it worked. Should I trust it to last?
also manually lower you headlights about half way ( raise them if their down
) and then grab the "round" part of the motor and try to wiggle it ... if it wiggled then you need to do the "free fix" part where it talks about the loose housing because this WILL lead to a stripped gear for sure. that's what did my drivers side in
scroll down a little from where this takes you :
http://www.bfranker.badz28.com/headl....htm#FreeGuide
