Pontiac Bonneville problem
thanks - J
P.s Is this a 90 or 60 degree V6?
99 used the 3.8L L36 engine (which is 90 degree), same as V6 F-bodies had
Here's instructions on head (and/or gasket) replacement:
1999 Pontiac Bonneville
Cylinder Head Replacement
Tools Required: J 36660-A Torque Angle Meter
Removal Procedure
Caution: Before servicing any electrical component, the ignition key must be in the OFF or LOCK position and all electrical loads must be OFF, unless instructed otherwise in these procedures. If a tool or equipment could easily come in contact with a live exposed electrical terminal, also disconnect the negative battery cable. Failure to follow these precautions may cause personal injury and/or damage to the vehicle or its components.
1. Disconnect the negative battery cable.
2. Remove the intake manifold.
3. Remove the exhaust manifold.
4. Remove the arm cover.
5. Remove the electronic ignition module.
6. Remove the spark plug wires.
7. Remove the generator bracket.
8. Remove the A/C compressor bracket bolt.
9. Remove the power steering pump.
10. Remove the belt tensioner. For VIN 1 engines, remove the supercharger belt tensioner.
11. Remove the fuel pipe heat shield.
12. Remove the valve rocker arm assemblies.
13. Remove the pushrods.
14. Remove the cylinder head bolts. Discard the bolts.
15. Remove the cylinder head.
16. Clean all of the gasket mating surfaces.
17. Inspect the cylinder head.
Installation Procedure
Notice: This engine uses special torque-to-yield head bolts. This design bolt requires a special tightening procedure. Failure to follow the given procedure will cause head gasket failure and possible engine damage.
Notice: This bolt [the cylinder head bolts] is designed to permanently stretch when tightened. The correct part number fastener must be used to replace this type of fastener. Do not use a bolt that is stronger in this application. If the correct bolt is not used, the parts will not be tightened correctly. The system or the components may be damaged.
1. Clean the threads in the block. Use a 7/16-14 tap.
2. Install the head gasket with the arrow pointing to the front of the engine.
3. Install the new cylinder head bolts.
- Tighten the new cylinder head bolts in sequence [see attached image] to 50 N·m (37 lb ft).
- Rotate each bolt 130 degrees in sequence. Use the J 36660-A .
- Rotate the center four bolts an additional 30 degrees. Use the J 36660-A .
4. Install the pushrods.
5. Install the guide plate.
6. Install the valve rocker arm.
7. Install the A/C compressor bracket bolt. Tighten the bolt to 70 N·m (52 lb ft).
8. Install the generator support bracket to the cylinder head.
9. Install the generator (alternator).
10. Install the electronic ignition module.
11. Install the belt tensioner.
12. Install the spark plug wires.
13. Install the power steering pump.
14. Install the fuel pipe heat shield.
15. Connect the negative battery cable.
