Sponsored by: CARiD
noise while turning?
Old Oct 7, 2005 | 12:10 AM
The PAT WS6's Avatar
Default noise while turning?
i notice there is a squealying/rubbing noise when i turn going slow coming from the rear of my car? what could this be i have and edlebrok torque arm/lca's/panrod bar and i checked all of that and sprayed some wd 40 on there but it still does it? i thought it could of been my tires rubbing when i had my nitto 315s but now i have new tires and they are 285s and the problem still occurs? so i dont think it could be the tires.
also another problem i have is when i am goin down the road i hear a constant thumping noise comin from the back left tire, so i take it up to discount tire and they look at it and its bent, and my tire wobbles when its on the car but i put my friends ss rim and tires on my car and his tire wobbles on there to? now how is that? i knw my rim that is bent causes the thumping noise i hope but could it be something else possibly? why does his tire still wobble on there?
thanks for the help guys
Old Oct 7, 2005 | 04:41 PM
ttttttttt
Old Oct 7, 2005 | 09:04 PM
should i just take it to gm and have them look at it? along with my bent rim?
Old Oct 9, 2005 | 03:19 PM
Shadow Assassin's Avatar
Don't know what to tell you about the wobbly tire issue, but as for the rear end squeak/grind you're hearing...how long has it been since you changed your rear gear oil & additive?
