Sponsored by: CARiD
Power locks not working
Old Oct 8, 2005 | 08:24 PM
BLURR's Avatar
Default HELP! Power locks not working
I am in the process of buying a 2000 WS6 Trans Am with 37,645 miles.
The power locks arent working right on it.
When you push the lock button on the remote, the lights flash and it arms the alarm and makes a click sound but doesnt lock either door. Same thing when you push the lock button on the door panel, makes the click sound but wont lock the doors. Same thing when you hit the unlock buttons, wont unlock the car. But yet the hatch release on the remote works fine. The only way to lock the car is by using your finger and pushing the slide lock manually or using the key.
What could be causing this and how to fix it?
Old Oct 8, 2005 | 10:25 PM
Spdmn75's Avatar
Sounds like the solenoids are bad in the doors. The clicking you hear should be the Body control module clicking it's internal relays. I would take the door panels off and manually test the solenoids.
Old Oct 8, 2005 | 11:39 PM
BLURR's Avatar
Thats kinda what I was thinking also.
Cause you can hear the clicking sound coming from behind the pass. kick panel. Around 36,000 miles both power window motors were replaced under warrenty. So Im thinking maybe they screwed something up when they did that.
Old May 31, 2009 | 05:50 PM
DGraboyes
Guest
Posts: n/a
ok im having the same problem and need some ideas of what to look for???
anyone have any other ideas besides testing the solenoids (why would they both go at the same time?)
Old Jun 10, 2009 | 05:30 PM
DGraboyes
Guest
Posts: n/a
anyone have an idea why both would stop working out of nowhere??
