Sponsored by: CARiD
Rt side turn signal
Old Oct 20, 2005 | 09:53 PM
stanley's Avatar
Default Rt side turn signal
My right side turn signal won't flash. I replaced both front and rear bulbs, it lights up it just doesn't flash. I think it is the flasher, the hazards still work just not the turn signal. Does anyone have pictures of where the flasher is located at or any other ideals?
Old Oct 21, 2005 | 07:09 AM
joe_kool315's Avatar
when you changed the right front bulb did you look at the connector part of the bulb? Was it all corroded? How about down in the connector itself, was it browinish black and slightly melted looking? This is a common thing with our cars. (assuming you have a 4th gen F-body as you didn't elude to your cars make/model) I'm having to replace BOTH connectors as well as both signal housing units to then tune of +/-$50 fo rthe connectors and $60 for the housings
