Sponsored by: CARiD
bad heater core??
Old Oct 21, 2005 | 10:31 PM
alconk's Avatar
Default bad heater core??
Well the weather is starting to turn colder now and I turned on the heat in my 94 Z and is was barely even warm. I have a new 160 degree thermo in it but it should still get hot. Could I possibly have a bad heater core?? Or could I be overlooking something?? Thanks
Old Oct 22, 2005 | 07:34 PM
FlamingChicken's Avatar
heater cores usually go bad by starting to leak. if your windows are fogging up when its hot out for apparently no reason, that is the biggest sign of a heater core leak. you can also just feel around the carpet plus you should be a little low on coolant. i think its gonna be the lower thermostat though. i know i have a 180 in mine and the air is just hot enough to keep it on.
Old Oct 22, 2005 | 09:01 PM
HBHRacing's Avatar
You can attempt to flush the heater core.
Old Oct 23, 2005 | 12:04 AM
alconk's Avatar
I have a 01 Sierra with a built 6.0 running a 160 degree thermo and the air is hot so I didn't think it would be that but maybe I'm wrong. How can I flush the heater core??
Old Oct 23, 2005 | 12:14 AM
BizZzatch350's Avatar
Moderator
Prolly just gunked up from being so old
