Pop up headlights
1. take the motor out, pry it open and take the gear and rotate it 180*.
2. replace the entire motor.
3. replace the gear with a brass one
i have heard lots ofsuccess with the brass gear with the exception of a few. i am one of the lucky few.. i stripped out 2 brass gears before just buying a new damn motor. up to you. gl with what you choose. also fyi, if you dont want the annoying grinding noise every time you lock your car, you can pull the fuze for the hl motor. -g
brass gear Lots of good info about our headlight motors too!
