Question on neutral safety switch
Clutch Pedal Position Switch Replacement
Removal Procedure
1. Remove the I/P retainers.
2. Remove the I/P insulator.
3. Remove the I/P knee bolster bolts.
4. Remove the I/P knee bolster.
5. Disconnect the clutch pedal position switch electrical connector.
6. Pull up to disengage the clutch pedal position switch from the pedal bracket.
7. Remove the clutch pedal position switch.
Installation Procedure
1. Install the clutch pedal position switch.
2. Align the buttons on the clutch pedal position switch to the slotted holes on the bracket.
3. Press the clutch pedal position switch down until secure.
4. Connect the clutch pedal position switch electrical connector.
5. Install the I/P knee bolster.
6. Install the I/P knee bolster bolts. Tighten the I/P knee bolster bolts to 2 N·m (18 lb in).
7. Install the I/P insulator.
8. Install the I/P retainers.
