Sponsored by: CARiD
95 TA has problems starting - VATS?
Old Oct 30, 2005 | 07:28 PM
RAREBREED95's Avatar
Default 95 TA has problems starting - VATS?
95 T/a Wont Start All The Time, If The Resistor In The Vat System Is Bad Will It Let The Car Turn Over But Not Let It Fire? I Replaced Coil ,icm And Optispark But No Spark Out Of Coil And The Car Will Only Crank . Some Times It Will Start And The Car Runs Great. I Havent Been Able To Start It For A Couple Of Days ... I Anybody Could Help , It Would Be Appreciated...thanks
Old Oct 30, 2005 | 08:14 PM
ACW's Avatar
ACW
If VATS were interfering when you try to start it, you'd have no cranking at all. The dash light for it usually comes on also.
