whining noise from gauges?
http://www.speedometershop.com/faq.html
(A) Maybe yes, maybe no. That "whirring" sound is usually caused by a dry cable. You can detach the cable casing at the transmission end and carefully pull the cable through. Clean it with solvent and let it thoroughly dry then grease the length of the cable with a non-migrating grease, preferrably lithium-based. Then feed the cable back through. DON'T FORCE IT! The last inch or so you will have to turn the cable a little so that it will line up with the speedometer. Reconnect everything and test drive it. If that didn't cure your problem then the speedometer head likely needs service.
