ALL headlights/high beams out
Drove the car at night for the first time in months last night, and noticed that my headlights are out. I tried to turn on the high beams and they're out too. Now, I have a hard time believing all 4 lights went out at once, so I checked the main fuse block (inside the door) and the fuses marked HL/DRL under the hood. Fuses are fine, and I even tried swapping a couple around, but still no dice. Fog lamps work, parking lamps work, all rear lamps work.
The only thing I can think of is that I did some work under the dash when I replaced my clutch return spring. Is there a wire under there that would keep the lights from coming on?
HELP!
Thanks,
-Mike
