Sponsored by: CARiD
which lights are supposed to flash?
Old Nov 12, 2005 | 02:41 PM
ninobrn99's Avatar
Default which lights are supposed to flash?
My blinkers just went out so i replaced the flasher and now its working again, but which one are supposed to flash? just the rears or the ones in the side pockets above the brake ducts?? this is on a TA btw.
Old Nov 13, 2005 | 06:27 AM
1QUIKWS6's Avatar
Active Streak: 30 Days
Rears should flash and the lights that serve as both DRL's and parking lights in the area above the open duct in your front fascia that you described.
Old Nov 14, 2005 | 07:50 AM
ninobrn99's Avatar
guess i need to replace the bulbs up front. thanks.
Old Nov 15, 2005 | 07:37 AM
WhiteBird00's Avatar
Ungrounded Moderator
Also, the front side markers should flash. With the headlights off, they will flash at the same time as the front lamp. With the headlights on, they will flash opposite the front lamp (i.e. they will be on when the front lamp is off and vice versa).
