Sponsored by: CARiD
low coolant level light
Old Nov 12, 2005 | 06:35 PM
fallenangell777's Avatar
Question low coolant level light
I have a 99 trans am that the low coolant level light came on and doesn't want to go away .I have replaced the water pump,both of the cooling fans,thermostat and engine temp sensor and still have problems the light still comes on after the car warm up.i should mention that all this happened on my way home from work also i should mention that during early in the morning when the temperature is cooler this doesnt happen only when the temp goes up like around 3:00 pm. Can somebody help me plz. thx
Old Nov 12, 2005 | 09:14 PM
tattooZ's Avatar
Default 'coolant light'
You did not specify if the coolant was actually low. I will assume that it is fine. These F-bodies have a bad habit of getting that light on all the time. On the passenger side of the radiator is where that sensor is. I tends to fail or get corroded. Check it, clean it, or get a new one. Most people just disconnect it altogether. Also wouldnt be a bad idea to check for air in your system and/ or burp it.
Old Nov 13, 2005 | 06:01 AM
I will try that thank you i just need to know how to check for air in the system and how to solve the issue.
Old Nov 14, 2005 | 07:11 PM
tattooZ's Avatar
Default burping coolant
start at step 12 of the 160 degree thermostat change.
http://www.installuniversity.com/ins...sity/index.htm
