Sponsored by: CARiD
Power Steering woes...
Old Nov 27, 2005 | 05:37 PM
OneMeanZ's Avatar
Default Power Steering woes...
Well, I knew this was going to happen sooner or later. Sometimes now when I'm slowing down to make a turn, like pulling into my driveway, etc. I lose the power steering and have to muscle it in there. Then sometimes it is fine. I think my fluid my need to be drained, flushed, and refilled. The fluid that's in there has seen extreme temperatures on numerous occasions, boiling and steaming before. What is everone's opinion here?
Old Nov 27, 2005 | 08:20 PM
dschmittie1's Avatar
Changing the fluid would be a good place to start. But from my experiences if it isn't low on fluid and your not getting the power assist at low speed turning (only time it really helps) then I think it would be pump failure. You might be looking at a new pump
Old Nov 27, 2005 | 08:53 PM
OneMeanZ's Avatar
Kinda what I was thinking, thanks for the response. If changing the fluid doesn't help, then a new power steering pump will probably be put on.
