Sponsored by: CARiD
overheating
Old Nov 27, 2005 | 08:20 PM
pontiac's Avatar
Default overheating
ok so on my way back to AUBURN tonight for a test in the morning and caar makes it 220 miles only 250 to my house.
so running fine then check guages light popes up and I look at temp and its high as hell so I turen off the key and cost into the sholder. pop the hood and radiator fluid steamming . so let cool call AAA and my friend brings me some water and i put in the radiator while we wate for tow ttrucj and we see it running out on what looks like the back side on the radiator close to where the thermostate is. water running down there. so where is it comeing from. and did not see any hoses bad yet look harder in light tomarow.
ANY SUGESTIONS????????????
Old Nov 27, 2005 | 08:46 PM
CRAGER's Avatar
Administrator
Thermostat or waterpump would be my guess.
Peace,
Craig.
Old Nov 27, 2005 | 09:51 PM
whatbrown's Avatar
just a possibility, but my car did pretty much the same thing when the electric fan switch failed to work and the fans did not come on.
Old Nov 27, 2005 | 10:10 PM
pontiac's Avatar
why did your car leak fluid becasue fans failing
Old Nov 27, 2005 | 10:50 PM
whatbrown's Avatar
it didn't leak fluid, the coolant boiled over because temps were too high.
Old Nov 29, 2005 | 11:35 AM
pontiac's Avatar
ok so I found a 4-5 inch crack in the plastic side of the radiator.
but I noticed something. the sensor on the passenger side (where my crack is) there is a sensor but nothing plugeds into it WHAT IS IT???
Old Nov 29, 2005 | 03:01 PM
Dmoney's Avatar
The low coolant sensor.
Old Nov 29, 2005 | 04:09 PM
pontiac's Avatar
thats what I found out too.... thanks Dmoney
but how come i have no wire with plug going to it i have looked everywhere
