Flickering Light problem figured out!!
I am not sure if I am super late on this information or what, but the last time I checked here I still saw alot of people asking why their lights flicker, and alot of people giving mixed answers. I decided to call a buddy of mine here at a local dealership. He's a service advisor and has been in the business 10 years, so he's seen the Fbody come and go.
Turns up.....Every flickering light Fbody he's seen has the same problem...
The Voltage Regulator inside the Altenator goes bad and allows the voltage to fluctuate up and down. He did say that they very rarely go out....they will just **** you off and make your lights flicker.
Hope I'm not too late with this info, I just figured since it came from a creditable source I'd let you guys know what I heard.
I am having this exact issue right now.. Voltage goes from 14.1 to 12.6 to 13.5 to 12.9, and so on..... It has weakened my battery to the point that some times my head lights will not open...
AIR pump kicking on....although I don't see why it
would when the engine is warmed up. Hmmmm.
From a quick glance at the Helms I don't think
the AIR pump kicks on except after startup.....
Thanks for the info!
Began to finish up the install and was randomly tightening bolts and very stupidly (because i didnt unhook the battery a second time after fireing her up to test my work) wrenched on the terminal bolt on the back of the alternator which grounded to the car and caught on fire and melted through the powersteering lines and began to smoke and burn even more. So I unhooked the battery and pushed the car out where I hosed her off. Turned out to be a mess and dealer eventually fixed it. But I did get find out the problem my car had and fixed it... I just caught the car on fire afterwards
(it was a very very small fire I swear)
