Clunking from rear when turning
Also I have a thump going over bumps from the rear and a creaking sound when I'm slowly going over uneven ground like pulling into my driveway. It is only coming from the right rear side. When I push down on my hatch I can hear a slight squeeky sound from what sounds like my shock. Is my shock gone?
As far as your squeaking, I have found that when it gets cooler, my sway bar bushings dry out, and if I get some lube up in there, it quiets down. Also, there are rubber insulators at the top of the springs. Maybe try some silicone spray, at both of theses places, and hope for it to penetrate. If not, you may have to take these part and manually add some lube.
