Rpms drop to 500
You'll have to do some research on your vehicle. Autozone prices the EGR at $150, and Advance doesn't have it. If you do replace it, make sure you thoroughly clean the carbon from the port hole. With that said, that might be all you need. Try cleaning it up and see if that helps.
Your symptoms definitely point to the EGR but there are other possibilities like a vacuum leak, dirty MAF sensor, or a computer problem (and probably others that I don't have any experience with).
Good Luck!
