Sponsored by: CARiD
Xmas maintenance
Old Dec 8, 2005 | 12:23 PM
cedric85745's Avatar
Default Xmas maintenance
here is a few little things about my car that I d like gone
1) like some many other, when I get to 25 mph and make turn in neutral , wide turn, the rear end does clack clack clack sound. some says its the u joint going bad , it sounds like that just want your imput
I d like to add that it never does that at speed or under 5mph
2) and thats the biggest thing, when making a tight turn at 25 to 35 mph I hear a loud humpppp, heavy vibratio coming from my left frond end , like if the whole part of the car want to die!!!, so I slow down right away and then drives normally , but this mean I cant make quick turns ( kind of suck I wanted a sports car, not an suv...)
please let me know what you think please , I d like to take care of that at the same time that I ll be doing LTs, ORY etc.. in the spring
thanks
Old Dec 8, 2005 | 06:54 PM
come on anybody
Old Dec 9, 2005 | 03:48 AM
jkichline's Avatar
I'm thinking motor and tranny mounts. I would check there after you make sure all the lugs are on tight. I had a rear clunking that turned out to be my tranny mount. The thump and vibration in your front end is probably either coming from your rack or motor mount.
Old Dec 10, 2005 | 08:27 PM
thank you , I ll look for those
1) soundscoming from the back while under no throttle or light, I thought it was the U joint, but I ll check the tranny mount, I have to anyway because when I shift sometime I feel like the tranny mount or something is going bad because I get lots of moving in the shifter, anyway that should be ok to fix
2) second think is the vibration, huuuuuuump sound I get from the front end on the left while making under 30mph sharper truns, this I dont know....I ll check on the rack and motor mount ( whats is a rack mount ?)
by no means this make the car not enjoyable to drivebut I want to get rid of this little things, I m sure I will with the help of everybody here and doing some search
by the way I got my tire balance this afternoon while doing a rotation and what a difference it make as far as vibration on highway, cant wait to put on the bilsteins HD and get soem more mod in january ( LTs, ORY, brakes , etc...)
anymore imput guys ?
Old Dec 12, 2005 | 05:45 AM
jkichline's Avatar
By the rack I meant rack and pinion in your steering system. I really don't know anything at all about the steering in this car as mine (so far) has always been fine). I thought that would be a good place to look for steering noises.
