Sponsored by: CARiD
Weird Experience..
Old Dec 8, 2005 | 02:18 PM
redfbird99's Avatar
Default Weird Experience..
I was on my way to practice and i was going about 45 and then the limit turned to 55 so i accelerated and all a sudden my car lost power, engine may have shut off because it didnt rev or give any sign of power when i pressed the pedal, i looked down and the check gauges light was on, i look at my oil pressure and it its totally down like its not even on.. so i went to the side of the road, turned the key off, then started the car again and everything seemed fine. If it helps it was probably 20 some degrees out, and i have a 1999 v6 bird. any ideas on what it might be?
Old Dec 8, 2005 | 09:33 PM
Syxx613's Avatar
go get a scanner and see whats going on. not much else i can say, sorry lol.
Old Dec 8, 2005 | 10:37 PM
Kenafin_02TA's Avatar
Did you have a Service Engine Soon light on when you restarted the car? Right before the car shutoff, did you hit a bump or anything like that?
If you have a code that's getting thrown, get it scanned and find out what that is. I'd also say start checking the connections to the battery and the computer, make sure they're nice and tight and in good shape.
Old Dec 9, 2005 | 06:43 AM
redfbird99's Avatar
no it wasnt the SES light at all, simply check gauges, had it checked with a scaner and nothing came up either, havent had a problem since so hopefully itll stay that way
Old Dec 11, 2005 | 08:12 AM
n2ojunkie's Avatar
If you looked down and seen 0 oil psi the engine was probably already off, so that would explain that. As far as the rest sorry cant help ya.
