Weird power loss when cold...
Ok so this has just started to happen to me recently. I live in Florida now so its not that cold here, but ever since I did the throttle body bypass when the engine is cold at low rpms starting off the engine has no power untill I damn near floor it (abov 80% throttle) Well I took the bypass off because I figured the tuning was off for the incoming intake temperature because its after the MAF. Well it seems to of solved the problem but the other day it did the same exact thing just not as bad now.
So what is the verdict. I run gumout fuel injector cleaner through my last 3 tank fulls 93 octane, and I have changed pretty much everything else on the car for maintainance wise. new wires, plugs, tranny, oil, diff, fuel filter, air filter, coolant ect. ect...
Like i said before it happens at low rpms 1st gear, starting from a stop and only when cold.
Thanks guys
